is terraflex the only one?
Im just about ready to pull the trigger on a leveling kit, and i was leaning towards the terraflex performance kit. my question is does anyone besides terraflex make a coil leveling kit? i tried looking at the evo one that was mentioned here on the forum but i couldn't find it anywhere.
I think there are a few other companies out there that make a leveling kit, but I have had the teraflex leveling kit on two of my jks. They are easy to install and warranty is great.
Do the tf performance kit that comes with sway bar links and you can go to 35s without issues. I had that for a while on my 13 rubi. Did have spacers on stock wheel.
Sent using smoke signals
You shouldn't run 35's with any leveling kit. Teraflex flex clearly states for tires up to 34"s. I know from experience that even 34"s will rub to the point where they broke my rear fender clips.
sounds like improper bump stop lengths or backspacing.. you can clear larger than that if you really want to.
