Terraflex 2.5 lift
Old 08-16-2011, 12:35 PM
  #31
Goranothos's Avatar
Originally Posted by ScottW
Loose steering can be corrected with longer control arms. You need to adjust caster since you lifted the vehicle.
No need for that. My loose steering was because the lift was improperly installed (loose track bar bolts). Now that they are tightened properly, the loose steering is gone.
Old 08-16-2011, 12:37 PM
  #32
Goranothos's Avatar
Originally Posted by LloydX-mas
DO NOT DO NOT reply negative to that survey. Read wayolife's post on this issue. You may never receive warranty work again if you do.
That's why I had the dealer do the install in the first place. Since they are sending me a check for $150, I have decided not to give them a negative survey. There are only 6k miles left on my warranty, so that is fast becoming a non-issue.
Quick Reply: Terraflex 2.5 lift
