TereFlex 3" Long Arm Kit
Most of you on this board are probably aware of this but I fiuredI would throw it out there for any other newbie like me that somehow missed it. I have read thread after thread trying to figure out which kit I was going to get and finally decided on the TereFlex Elite 3" Long Arm. By the way, if you decide to buy one of TereFlex's kits with the 9550 shocks they are on back order for a bit. Good excuse for me to buy Bilstein 5100s.
If you plan to purchase a TereFlex Long Arm Kit you need to pay special attention to this note. The TeraFlex Elite LCG 3in Long Arm Kit is designed to fit up to 35in tires(aftermarket wheels with 4.5in backspacing or less is required).
I called TereFlex to get more detail on this note. I have the 18" Rubi wheels with Bridgestone tires on my X. I was told they will not work. The tie-rods will make contact with the wheels. Anyone have first hand knowledge of this?
So if you are like me and you saved money for the lift, make sure you have the money for the tires and wheels at the same time. I know most people do both at the same time anyway.
I have the money for the tires but wanted to use it for the RIPP long tube headers and MBRP Cat Back.
OEM wheels have 6 inch backspacing and you need 4.5 or less to make up for the wider tires. If you want to keep your OEM wheels, you will need 1.5" wheel spacers. Pretty much every lift that I know of requires 4.5" of backspacing or less.
Thanks for the advice!
You could run that lift with the stock wheels and factory width tires.
I was going to buy new tires anyway but need another month to secured the funds. I think I will be ok to wait
Your Rubi has 18" wheels? I thought all Rubi's came with 17" wheels. Anyway, as mentioned I would just get spacers and run bigger rubber. Running Rubi 32" tires with a TF 3" LA would, at least in my opinion, look pretty odd.
https://www.jk-forum.com/forums/show...+wheel+spacers
Also click on the Advanced Search word...upper right and enter spidertrax.......lots to read
Party On!
P.S. also check this out....
https://www.jk-forum.com/forums/show...ight=2.5+lifts
Party On!
Yes, even at stock height you would need spacers with wider tires...but I don't know if they even make a 12.5" wide tire in that small of a size? lol
Nothing will contact the tie rods with the Teraflex 3" lift. You'd be using the stock tie rod. Teraflex either made a misprint or someone who doesn't know tech made an assumption. I ran stock 17" wheels with 35/12.50/17 Mickey Thompson Baja Radial Claws when I first installed my 3" Teraflex longarm kiut, and the tires rubbed slightly on the frame rails at full lock, and the top of the spring perch at full up travel. But it was 100% driveable. I just adjusted the steering stops till I had a set of spacers installed.
