teralfex level question
Old 04-11-2011, 06:58 AM
ukjonese's Avatar
Default teralfex level question
http://www.northridge4x4.com/proddet...155200&cat=272
A buddy and I put my leveling kit on yesterday (link above) and new shocks I like the look but it still looks as though its slanted to the front and not as level as I have seen pics on here..
My question: When taking the stock springs out and adding the new spacers in should I have removed the softer stock spacers completely and only added the new spacers or should I have left them in and also added the new spacers???
FYI:: I used the stock spacers in addition to the teraflex spacers..
Thanks guys! I appreciate your help!!
Old 04-11-2011, 07:00 AM
Abacabb's Avatar
I used the stock spacers.
Old 04-11-2011, 07:04 AM
ukjonese's Avatar
Do you have a pic of you jeep you can post so I can compare? Maybe I'm just being too critical but I see a small slant and it drives me crazy..
I am putting new tires on this week so maybe that will help?!
Did you get an alignment afterwards?
4fit?'s Avatar
You are talking about the stock isolaters. Yes, they should be left in.
Old 04-11-2011, 07:10 AM
Abacabb's Avatar
Hard to tell but theres a slight rake. 1/2 spacer would fix it, but it's not a big deal for me.
Old 04-11-2011, 07:50 AM
Matador's Avatar
When I originally installed my leveling kit (when I had it) I made the mistake of not using the stock isolators.....I had to do it all over again.......you are supposed to leave them in
I know a few people have made the same mistake....it's all good....it help give me practice for when I installed my lift
Old 04-11-2011, 08:32 AM
Battlefrog's Avatar
X2..... What size coils are you running in the front? I switched out my 16's for rubi 18's and no more raking....
Old 04-11-2011, 08:49 AM
racin444's Avatar
It should level it out as it did mine. If not then take the spacer out of the rear to accommodate any rake. I did my front first to see if the rear spacers were needed (directions said rears may not be needed) and I was sitting Baja truck style.
Old 04-11-2011, 09:45 AM
ukjonese's Avatar
Originally Posted by ludski
i put my teraflex pucks in and left the isolators in (stock "spacer"). it helps hold and soften the coil.
but mine is perfect. prob a little slant, but barely any to be noticed.
but if yours is really noticeable, be sure that your rear spacer is in place correctly. took me a while to get the little part to snap in right.
yea we had a time with that workin out on the rear.. but i think we got it in place.. I haven't noticed anything strange while driving it.
honestly I liked the look better before i put the rear spacer.. I may consider removing it again..
I appreciate all the advice guys, thanks!
Old 04-11-2011, 09:46 AM
Sponsoring Manufacturer
TeraFlex's Avatar
A alignment is not needed and is a waste of $ unless you have front lower adj. control arms. Did you loosen the front control arms before you installed the kit?
Quick Reply: teralfex level question
