TeraFlex Yokes?
TeraFlex Yokes?
will the TF yokes fit on the JE Reel drive Shaft?
How is the quality between the Reel's and the Wood's drive shafts? are they comparable?
not sure about compatibility of yokes,but a yoke designed for a 1310 ujoint should work with any 1310 shaft,I have Woods front shaft(with teraflex yokes)and JE reel rear(that adapts to oem flange),have had no problems with either but the Tom Woods shaft does look like a better built shaft and very nice u-joints.if could do over would have woods front and rear with new yokes on both(had to buy what was in stock at times when had stock shafts fail,thats why I am running different shafts)
I've got Reels and have had no problems with them. Woods has a great rep and they are pretty shafts. I went with Reels because I cam across a great deal on Reel 1350's; good enough that I couldn't pass it up. Don't ask; it was a year ago.
Had an issue with a Reel flange -poorly machined. The Woods 1310's are easily lubed, they have the zerks at the end of the caps. Plus they have a warranty second to none in the industry, both joints and shafts.
Because of the warranty I'd probably go Woods if I did it again. My 1350's have grease serks in the ends of a cap. Without them they are impossible to grease if you have skids. One of the reasons I went with Reel at the time, in addition to a "one of mistake killer price situation" was that I wanted yolks not flanges and Woods didn't offer them at the time.
Either way both beat the heel out of the stock POS shafts!
