Teraflex Tire Carrier?
Old 02-28-2014 | 08:14 AM
  #641
TeraFlex's Avatar
Sponsoring Manufacturer
Originally Posted by xj-boonie
On the accessory/high lift mount, what is the thread size for the upper threaded bung not used for a hi-lift?
5/16"-18 That hole is there so you can run the RotoPax LOX-T-Handle through the Hi-Lift and into that threaded bung.
Old 02-28-2014 | 03:39 PM
  #642
xj-boonie's Avatar
Thanks! I want to put a bolt in there for now to stop the rust that's started.
Old 02-28-2014 | 04:05 PM
  #643
cdenny's Avatar
Originally Posted by hothondaguy
Has any one tried to use the smittybilt oversize carrier and the teraflex hinge as a combo? I'm already running the smittybilt but am buying the teraflex hinge and carrier tomorrow and was curiouser about the functionality with the smittybilt carrier.
Have you installed this set up yet? I was going to do the same thing if it works
Old 02-28-2014 | 04:16 PM
  #644
jeepsta's Avatar
My setup!
Old 03-02-2014 | 06:52 PM
  #645
First's Avatar
Look at page 8 or 9 on this thread. A few pics there.
Old 03-03-2014 | 05:09 PM
  #646
4wheels4life's Avatar
I've had a few requests asking about the TF carrier and smittybuilt tire carrier combo and here are the pics of mine.
ID:	534941   Click image for larger version
ID:	534942   Click image for larger version
ID:	534943   Click image for larger version
Old 03-03-2014 | 05:45 PM
  #647
Hskr4x4's Avatar
Old 03-03-2014 | 06:05 PM
  #648
First's Avatar
Thanks 4wheels4life, that looks good. Looks like a pretty straight forward mod... I will do the same
Old 03-03-2014 | 07:09 PM
  #649
TripleBJK's Avatar
I want to use the same setup. Any problems with the install?
Old 03-04-2014 | 03:49 PM
  #650
No none at all. I just made that relief cutout on the side of the mount for the smitty carrier so it would sit flush and used the supplied spacers used for the original tire carrier. I also put some washers under the upright spacers to keep the uprights from contacting the terraflex mount. All very easy. Very solid.
Quick Reply: Teraflex Tire Carrier?
