Teraflex Tire Carrier?
Old 11-19-2013, 06:49 AM
  #601
mattgt5's Avatar
Originally Posted by Gossamer
Did they cover this under warranty?
Yes they did. Very quickly in fact.
Old 11-19-2013, 08:44 AM
  #602
scamp_71's Avatar
I was a little worried myself after reading about a few of the adjustable carriers breaking at the weld. Even though I'm only running 35s, I emailed TF, expressed my concern, and they sent me the new gusseted version no questions asked. I've always been impressed with TFs customer service.
Old 11-19-2013, 10:01 AM
  #603
robsjeep9's Avatar
Anyone have pics of the redesign with gussets or explain to me what they are and do? Thanks I'm about to buy 37's and possibly this TF product
Old 11-19-2013, 10:26 AM
  #604
mattgt5's Avatar
The cylinder which the spare mounting plate is welded to was the weak point. Imagine a cylinder with a semi circle cut out on the left and right side, then a flat plate welded along the top and bottom portion of the cylinder. That was the original design. Now weld in some concave steel to the semi circle and to the plate. That is the gusseting. Click image for larger version
ID:	511974 In this picture you can see where the weld stops. It's mirror image on the bottom but the sides are open. They filled in the sides with steel and welded to both sides.
Old 11-19-2013, 11:28 AM
  #605
robsjeep9's Avatar
Ok thanks ......
Old 11-19-2013, 04:53 PM
  #606
WranglerJA's Avatar
Default Great product
Just installed. Took me longer than I expected but I took my time cleaning, waxing before the install. I didnt like the exposed holes so snapped in fender clips from my GM and painted the outer torx bolts with a PVC pipe . Should of powder coated them first but turned out good.
ID:	512019   Click image for larger version
Old 11-19-2013, 04:55 PM
  #607
xkid's Avatar
Originally Posted by BigMike
Sorry, not drinking this KoolAid. Might be good for mallcrawling with a big wheel/tire combo but over time it will not hold up like a bumper mounted tire carrier will. $700 for what is basically a hinge plate. Or, $865 for an entire bumper and tire carrier that works with the tailgate? Hmmmm
Attachment 511867
Who makes this bumper?
Old 11-19-2013, 05:07 PM
  #608
Marks101's Avatar
Aec makes thst bumper
Old 11-19-2013, 06:11 PM
  #609
brighton's Avatar
Here's a pic with added gussets. The pic that mattgt5 posted has the sides open which was the original design.
Old 11-19-2013, 06:21 PM
  #610
brighton's Avatar
That's a great idea using pvc pipe to paint the torx bolts.
Quick Reply: Teraflex Tire Carrier?
