Teraflex Tire Carrier?
#421
I'll clear up right now. This is teraflex hi lift mount with rotopax mounts. You can only fit a 2 gallon for body clearance with gate all the way open on the right. you can purchase an addtl mount for the left hand side to fit a 3 gallon as pictured at least with a 35" tire. I have had this for awhile now as i got in on the first order shipment. The quality is great but i have problems with the design. First off the cb antenna is mounted very close to the high lift which interferes with its ability (see other posts). In all honesty your hi lift has become an accessory mount. Yes its great quality and you can fit a 2 gallon and a 3 but if you actually have to use it you are gonna spend a lot of time to get all the "stuff" unbolted!. This is mounted on a 42" hi lift which was recommended because of clearance in case the gate swings shut with the glass. Not to mention you have to cut down the 42" a few inches to clear it. Dont most of you run at least a 48"?? I am actually thinking of selling the whole package myself (for all of those waiting on backorder). Just my .02
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=446330"/>
Im currently trying to find a better way to mount my rotopax. The tire carrier itself is awesome!!
#422
Well if the hinge can bear the weight, you can still mount 5 gallons on the jack then another 4 or 5 gallons on the spare. I can't see myself needing more than that for any trip I take...personally i don't really care whether or not the rotopax mount bolts into the jack.
#423
Will I have fitment issues with teraflex hinge, stock carrier and stock wheel? Just going to be putting a 33" on the stock wheel. On the TF site, it says there are issues with stock wheels but that seems to be only if you run their adjustable carrier. Thanks.
#424
#427
I have the carrier on my rig holding a Large 37"-13.50"-17" Nitto Mud Grappler and let me tell you 100% no rattling of any kind... The gate doesn't bow at all... And Is much stronger and engineered very well... A lot of thought went into the design of the carrier... Overall one of the best mods I have on my rig...
#428
Attachment 446444
Attachment 446445
Attachment 446444
Attachment 446445
#429
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=446444"/>
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=446445"/>
#430
