Teraflex Tire Carrier?
#302
what is the intent of the 3 smaller holes tapped towards the left side of the hd hinge? is that for a cb mount potentially? my "old style" teraflex cb mount is NOT compatible with the hd hinge, which sucks. just wondering if there is a bracket that teraflex is putting out for this carrier or if i need to do some fab work?
#303
#304
#305
The factory bolt size for the bolts that holds the tire carrier at M8x1.25x30. You should get 2 bolts from Lowe's or home depot that are about a 1/4" longer than the stock bolts
#306
#307
I'd do that except for the fact that I've already used that location for a bracket that I fabbed up for a backup light. What are the 3 smaller tapped holes for towards the left side of the carrier? The hi-lift mount holes are on the right and are larger so not sure what the other 3 are for. I'm thinking these would work for attaching a home brew cb bracket...
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=429584"/>
#308
Attachment 429584
Attachment 429584
#309
#310
I already had a spacer because of the size of my tire I needed more height to clear the bumper. Here is a picture of the install right before the tire was put back on, and one with the tire on. The new terraflex hinge only spaces the tire out about 3/16 of an inch. If you needed a spacer to lift your tire for clearance before, you will need one again.
Attachment 427863
Attachment 427863
You may want to look into the adj tire carrier bracket they offer too.
