teraflex rear drop bracket for trac bar
ok when i installed the rear drop bracket on my jeep for my trac bar i didnt even think about it rubbing the factory shocks. i ended up having to grid some off the bottom of it after i noticed it had been rubbing the shock slightly but i dont think was enough to hurt. after i modified it i pulled it on a hill to see if it would clear and noticed that the right rear shock had fluid running out of it in a steady stream. though that it might've punchered it but looked closer and noticed it was comming out of the very top under that plastic cover. has anybody else had this problem? the jeep dosent ride any different and you cant tell it so im last as to whats has happened here and the place the bracket put in it wasnt even deep it was just rubbing against it. i have the 2.5" bb and stock shocks with extensions
Sponsoring Manufacturer
The 2.5" rear drop brackets are not out yet. I've been told next week.This sounds like he is using a rear trackbar bracket from a 3" kit (#001954000) which is fine as long as you have a shock relocator kit (#001554700) on that passenger side shock.
