Teraflex quick disconnects
No issues with the combo, other than some minor rubbing when disconnected and fully stuffed. OME lifts don't come with any bumpstop extensions, so that is really the reason for the rubbing. Of couse, your tire size and wheel offset will affect this as well. ...Which is probably the reason they aren't included, come to think of it. I think you will be happy with them, just make sure to shorten those bolts as previously mentioned.
Here are a couple shots from when I put them on at the house. Flexed and Stuffed. You can see where the tire is rubbing a little on the flare in the first one. In the second one, you can see the limit of the OME shocks. I wish they were a little longer. I didn't notice that limitation until after I added the disconnects. If it didn't ride so nice, I probably would have been mad... Ha ha.
