Teraflex prerunner kit without longarms ? I want to do some high speed stuff.
Teraflex short arm
I was pretty close to buying a new Ford Raptor short cab the other day, but my financial angel on the shoulder got to me and decided to mod my JK-U and save $40,000 or so and get a similar experience.
Is it possible to run the TeraFlex Prerunner kit without the longarms, or possibly go to a long arm setup down the road ? I've been running a 3.5" coil lift with stock arms and have no complaints regarding road manners. Are the speedbumps specific to the prerunner kit different than the standard ones because of the different axle travel path when using long arms ?
Also, would there be a performance hit by running 2.5 or 2" lift instead of a 3" ? Right now I am running 35" tires on stock ride height and loving the low center of gravity. I suppose the lift is where the extra up-travel comes from.
My other upgrades will be the goodyear duratracks, a performance brake kit (not sure which one yet) and either a supercharger/exhaust system or a hemi swap.
Kind of considering the supercharger as the jeep is balanced well right now, a hemi swap would throw a lot of extra weight onto the front.
I ran the jk hard for 100 miles. Short arm kit is plenty. Bumps stops are well worth it as are the fox resi shocks. It bottoms out on the back fenders and rock rails a bit so I'll let that looked at Monday. In general the rear was what bottoms a lot. I had lots of gear in the back though. But overall worked pretty well. Way better in the tight twisty ridgelines and washes than the 4 door raptor. But raptor is better at high speeds over rolling washouts.
Originally Posted by mrmike
Coil over front an rear would be ball park 10-12,000 (depending how many parts you need) according to ORE. Lots of labor and lots of new parts ( arms, steering, drive shafts, etc). 12k buys you a turn key Bronco pre-runner...
JK-Forum Founder
$12k is way high. The Evo coilovers are about $1600 front and $3500 rear. I was quoted 1k labor to install. The new soon to be released Evo bolt on coilover kit is supposed to be around $3500 front and rear combined from what I hear. The double throw down is more expensive, but not needed unless you are going 80 mph offroad.
Evo coil over.
If those prices are correct then absolutely go that route. I didn't want to cut and weld do much on a two week old car. But I'll probably convert later. There is no substitute for wheel travel. Regular 3-4" short arm kits only give about 9" of travel. That's not really enough for going fast over big bumps.
But again my car worked pretty darn good on 85% of what I drove it over.
JK-Forum Founder
the new evo entry level bolt on coil over kit requires NO cutting or welding, is super easy to install and again, by comparison to their evo lever DTD setup, costs a fraction of the price. best part about is, this kit offers a true 12" of travel up front and 11.25" in the rear and, in addition to providing excellent flex, it can also eat up the bumps way better then the TF kit. granted, it does still cost more but, you do get what you pay for...
I don't know much about the coilovers for jeeps. Do they come with a cushy bump stop like the teraflex speed bump ? I assume the price includes the shocks? Why are they better than the teraflex kit ?
Also the 12" of up travel, how high dies the vehicle have to me jacked up to attain that ? The teraflex achieves 8" with a 3" lift. I'm running flat fenders and I was planning on trimming the pinch seem and rock rail. And clearance the front bumper. With the coilovers how much up travel can I get with a mild lift height ?
JK-Forum Founder
please know that i've run TF kits and can tell you that they're nice and i recommend them all the time. but, you're kidding yourself if you really think their pre-runner kit will perform better than a good set of coil overs. granted, coil overs are a lot more expensive and, if you're working within a budget, the TF may be the way for you to go.
