Teraflex mystery bracket
#41
well if i could read i would have caught the responses... i guess i will be installing the shock relocation bracket tonite... still not sure what to do about the rear swaybar... not really feelin wheel spacers...
#45
I have same bracket with my teraflex kit
I have the same unused bracket left over from my teraflex install,but real reason I am responding is to tell you to loose that rear track bar bracket,under maximum compression on right rear wheel track arm bracket will push right into your shock body and cave shock(exactly what happened to mine)need to switch to an axel mounted bracket(teraflex now makes one its around $90)
#47
So I guess my question is .. I have the frame mounted rear trackbar bracket .. do I need to call Tera and use the axle mounted bracket instead or do I need to use hte shock relocator bracket or am I fine???? I definetly do not want to tear up any shocks
