Teraflex mystery bracket
actually, that is a JK frame mounted rear trac bar bracket... i have it installed on my JK right now. the "mystery" bracket in question appears to be the TJ axle mounted trac bar bracket
That's the shock relocation bracket
That's the shock relocation bracket. it will push the bottom of the shock out enough to clear the drop bracket from hitting the top of the shock.
That bracket was not originally included in the kit, so it probably wasn't put in the parts list. They should have known that though and been able to tell you what it was.
the other guy is right
that is the bracket to space out the rear right shock, so it doesnt contact the track bar,
i believe that is a new piece, should only be used if your shock looks like it will contact the track bar
tera did this "update" before when they started including longer sway bar links and different rear brake line relocator brackets
