TeraFlex Lowers
TeraFlex Lowers
I just got my TF Front lower control arms today from Northridge. Does anyone know if they are supposed to come with zerks? Mine just have a plug in them. What size zerk do I get? Also, is anyone out there who is running just the lowers on front know what a good length is to start with for a 4in lift? It's a bit late to call David, so this is my night source of info.
Hope that helps!
Did yours come with zerks? I don't have adj uppers, so I was wondering if my lower adj should be different than recommended. Also , can the lowers be changed with the jeep on the ground or would it be better to jack it up to change them?
I got my girlfriend to pump the jack a bit (under the diff) to get the bolt holes to line up on the first arm, didn't even bother to call her for the second.
Make sure you're setting them to equal lengths and use the recommended length, or a little bit shorter. 23 1/4" would be a good number with the stock uppers.
See how it drives, then adjust more if needed. Also, an angle indicator on the lower C will give you a good idea of where it's at.
As for the zerks, when I bought my CAs some came with zerks and others were incomplete. Make sure you get them ASAP because I don't think that you should ride them with out greasing them first. At least that is what I did. I don't remember the size of the zerks. Sorry
