Teraflex lift
Teraflex lift
So im looking at the different teraflex 2.5 budget boost options. I see there are three, one that includes shocks, another that has shock adapters instead of shocks, and another that has no shocks. I'd like to know what the big differences are between all of these. Would it be a waste to go for the cheapest option without shocks? What is different between the shock adapter and the shocks? What do you guys recommend? Help meeee!!!!!
I believe the no shock option is for people that are going to be getting a different brand aftermarket shock(I.e. Bilstein,Fox,OME, etc.). The cheapest route would be the adapters.
Originally Posted by Keyrat13
Whats better about the coils?
a budget boost is just a puck which goes on top of your coil springs. This often makes the ride of the jk much worse. Coils on the other hand are just longer coil springs which provide the lift without to much sacrifice of ride quality (on and off road) I would just spend the extra on getting the springs, dont go with a BB. As for the shocks, now that the jk would be lifted you would need longer shocks (ie extension or new ones) no shocks means that you'll need to buy a different brand, shocks means their brand is included, extensions just gives you the height to match the lift
You should be able to get a TF 2.5" coil lift with adapters for around $425 shipped. Call Dave @ Northridge or Bryan(Bustabizz) @ 4wd.com. Either of them will give you a great deal on this kit.
