Teraflex leveling on rubicon (no drill)?
I just ordered a teraflex leveling kit (spacers) for a 2013 Rubicon. I have heard the stories about the new sway bar links not fitting the front disconnect sway bar. You have to slightly drill out the sway bar. (not real crazy about that). teraflex said they have fixed the problem but still many older versions are being sold by vendors. If I receive the older version, Is it possible to use the rear links (longer)from another jeep on the front of a Rubicon. I know you do this when using the 2.5 coil lift. Has any one ever used longer rear links on the front. I really just dont want to drill
The rears will be too long for two inches of lift. My front end sits at 3.5" over stock height with a 2.5" lift and the rear links has the front sway bar sitting near level.
