Teraflex Leveling Kit Swaybar links too close to springs (rubs in some cases)
Attachment 242641
Here's mine... Notice the angle(shot from front). I couldn't tell from yours if it's in correctly
ah man, that stinks. Whenever I'm fixing something, I'm always happy when it's something easy. Good Luck with it, let us know how you end up fixing it.
Heres an interesting newb question...should I have removed the bumpstops before installing this pucks and isolator? I see that done in other kits and even the Teraflex 2.5 BB lift. Any ideas?
...maybe not, that is if I were installing new bumpstops from teraflex.
Originally Posted by scrappy
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=242641"/>
thanks for looking out, but that's how they are. It's a dark picture, but that's my drivers side front, taken from over the front bumper.
Im starting to see a trend with Teraflex BB videos...loosen the lower and upper control arms and trackbar and dont retorque them until the vehicle is put back together and on the ground, tires and all. I guess I know what will be done tomorrow.
Your vehicle is lifted so you can't compare your springs deformation to the pictures of springs bearing weight.
If you still have bow in your springs when bearing the weight of the vehicle, as one other poster said, you probably need adjustable lower control arms. Your caster is going to be off after this lift and that is the price of a budget boost. Adjustable lower control arms will fix it.
