Teraflex install help..
Just put on the TeraFlex 2.5 BB, and took it for a little spin and heard a squealing noise.. The rear swaybar on the driver side is rubbing the rim ..
I was thinking you didn't need an adjustable rear track bar for a BB lift? Anyone have any suggestions of what could be possibly wrong?
I am guessing the rear axle shifted to the right and now makes it rub against the stock rim.. What can I do short of buying an adjustable track bar?
Here is the images left and right.....
The rear sway bar links are to be mounted on the INSIDE of the sway bar, NOT in the stock location on the outside.
You can kind of see my sway bar link in this pic. Mounted on the INSIDE of the swaybar.
Mine are also on the inside. I also think the trackbar relocation bracket helps with this. It looked like you don't have the trackbar relocation bracket installed.
Check this thread for info on the relocation bracket.
https://www.jk-forum.com/forums/modified-jk-tech-2/tf-bb2-5-trackbar-bracket-33838/
sweet.....
You guys are awesome... I was thinking about that when I installed them it looked close.. Would I install both sets on the inside? Or should I install just the side that is rubbing on the inside?
Both of mine are on the inside. I would do both on the inside just so they are the same on both ends. Don't know if it's necessary or not though.
Thanks to everyone for the suggestions...
https://www.jk-forum.com/forums/showthread.php?t=33838
I just read your post again and thought I would comment back. Yeah I ordered my BB from Northridge and it didn't come with a trackbar relocation bracket. I have read about these bracket things that were installed and the stress breaking the welds.. I am hesitant on adding this... Does anyone know if adding an adjustable bar has broken the welds? The bracket seems like it just lowers the bar putting a different angle of stress on the welds... I am guessing the adjustable mounts stock location and doesn't have the angle....
The TF bracket requires an additional bolt (you must drill the hole) and this provides the extra support required to help prevent it from breaking the bracket. T
$30 vs $200. Your ride and your money, so you get to decide.
