Teraflex drive shafts with AEV 3 lift and arm brackets
All,
I am looking for a little help.
I have came across a great deal on a set of used but never installed Teraflex front and rear drive shafts. ( plus my front boot has been gone for 20K) ---I know I know---
I am currently running an AEV 3.5 coil lift with correction brackets on my 08 JKUR.
My concerns are :
Will I need to go to adjustable control arms or can I run the drive shafts with out any issues and the correction brackets?
If I need to go to control arms what should they be set at?
If I do go to arms I would bite the bullet and get all 8.
Thanks
My concerns are :
Thanks
The correction brackets are the new longer control arms. The brackets are just the cheaper alternative the downside being yuo cant adjust it the camber to a perfect angle. You'll be fine with just swapping out the shafts.
