teraflex disco/wrangler surprise
Sponsoring Manufacturer
I didn't use those dinky nylon locks... It is the kind where the nut has little indentions on one side of it. I thought the nyons where called nyla-locks or something. I dunno. These are only grade 5, I used some grade 8 locknuts and flatwashers with them. I am hoping the won't move until I get some replacements.
That is strange the same thing happened to you. Maybe we drive too aggressively?
Think this will be ok? I snapped a couple photos before I wiped it all down:
I was going to order a replacement, but I am thinking I will just locktight this and see if I can just get a hitch pin like what came in the kit to begin with. I inspected the piece and saw no damage to it or the link, and like stated above the Teraflex hardware is probably about the same. I do like the way the hitchpin they sent retains itself. I doubt the one I replaced it with could fall out (it is pretty tight) but the other seems really solid. I will probably order the entire new unit though, just for piece of mind. I sure hope it was just a random fluke. Driving around with half your swaybar connected makes things squirly.
Don't let one or two bad reviews get in the way of a great poduct. I disco my swaybar links at least twice a month when I wheel for the past year and no issues whatsoever.
I'd rotate that pin so it's up and down and not sideways.
These are mine and how I mounted them:
I am in no way giving it a bad review. I don't know what caused the issue. The link itself is still in great shape, just the hardware is gone. I doubt they made the hardware. I would still recommend them to someone looking for links.
I really think someone helped this happen. I know it seems far off, but it does not show any of the signs of a part that worked its way out over a period of time. The first and major reason I think this is that if it got loose and was moving around the hole it goes in would be much larger. Also the threads would be flattened from moving around. I also believe that if it worked its way out there would have been clunking before it came out. There is no way it went from tight to completely unbolted without a clunk. Although the hitch pin was gone, the rod the link goes on was still inside the link. I do not think the link (that slides off pretty easy) would stay in place while the nut unbolted itself with nothing to hold it on.
I do not know how this happened, and probably never will. I do not in anyway think that here is any fault in Teraflex's product. Even though this was outside their responsiblity, Teraflex has been very helpful. They are a fantastic company with great customer service that makes incredible products. The build quality on this Teraflex lift kit is great, and I would recommend it to anyone.
