Teraflex brake line anchors
I was chatting with Teraflex about their brake lines and the rep on the other end noted that brake line anchors work for the front and the back. I already have some for the front and see how they work but it got my intriqued as to how they work in back. I asked the rep for a picture which they did not have but said it goes on the shock mount same as the front.
Has anyone heard of this or seen this? I thought the anchors were only for the front.
I've seen a spring on the rear brake lines, but it was a show truck so I assumed it was to clean it up. I can't see attaching an anchor to the shock bolt though- top or bottom seems like you'd be asking for problems.
Actually, I stand corrected. I'm thinking I saw the Teraflex things used to keep the wheel speed sensor out of the way on the front axle. Not the brake line.
they make a longer one that would work well on the rear. i have been running them on the front since the day they came out and I can see how they would work well on the rear. especially if you are running extended rear lines.
