Teraflex BB and right pull. tried everything.help!
#21
update.
loosened all control arms and jumped up and down/ pushed side to side on jeep. no change. I did manage to strip my rear track bar bolt and now need to cut it off and replace it
Looks like I'll take it to another alignment shop and see what they can do for me
#22
You might try turning your ESP off and see if it still does it. I'm not an expert on the JK's at all. But that is a system that is running and could, given the right problem or circumstances, cause it to try and correct itself. I might be wrong, and I am sure someone here will correct me if it can't be it, but it cost nothing to turn it off, or pull the fuse for it and try. There is an active post now about the ESP turn off, link is here Disable ESP
#23
#25
It actually totally would make sense because my gas milage went down with the lift and not with the tires (put 33's on about a week before the lift)
#26
Please keep us posted. I am in the middle of researching which lift to purchase. It sounds like something odd, not just a bad lift part but I still would take all of that info and make a dicision on what i want to do. I have to say it makes me nervous about doing it myself vs taking it to a shop. I hope you figure this headache out.
#27
turned off esp. still pulls, but much less rolling resistance and my gas millage is climbing. The orange instrument panel light with the swerving road goes on when I hit the off button, is this normal?
Can anyone tell me the size of the rear track bar frame bolt? I need to go get a new one today. I know it's 21mm hex head, but dont no any of the other specs to ask for at the hardware store.
thanks as always.
Mike
thanks as always.
Mike
#28
thanks as always.
Mike
thanks as always.
Mike
https://www.jk-forum.com/forums/central-canada-58/perm-esp-disable-84769/
Try that.
#29
did you check your tire pressure? Im sure you did.. but hey, you never know.
and I think whomever told you the jeep has a natural drift to the right was lying. mine drives straight as an arrow... And it has never been aligned, even since the lift.
also, caliper dragging? does the wheel spin the same as the opposite side while off the ground?
#30
Along the lines of a caliper dragging.....that's a good thought too, racer83l.....you might check out the brake hoses. If one was stretched too far, this can cause the hose interior to break apart and act as a check valve and keep some pressure applied to the caliper. That would be something worth checking as well.
