teraflex 6 inch long arm!!
I am curently running 18 inch rockstars with 4.5 inch backspace on 37x13.50x18 inch nitto mudd grapplers. I just put inch and a half wheel spacers on to see if that helps. Going to try and adjust the rear control arms this weekend because I am getting into the back bumper a little and that would make perfect sense. I can not thank all of you enough for all the help please keep in touch and I will keep you updated. Thanks again.
Are you hitting the brake line brackets on both sides? If its only hitting on one side then I'd say your axle is shifted which would also explain why your track bar mount is hitting your shock.
They can achieve any caster # they want with the arms but running to high is dangerous for the DS.
Its a balance between caster/pinion unless they're running a aftermarket housing like TF's or DT.
For the op
You need a wheel bs of 3.5" for 37x12.5 tires on a lcog lift. You may also need to address the bump stops and add limiting straps for proper set up of the suspension.
Are you sure its the tires hitting the brake line bracket and not the sway bar? I have had this lift for a few years now. You do have to trim the upper bolts on the rear sway bar to clear the brake lines. If your tires are hitting the brake line bracket then you need to make sure the rear axle is centered and possibly add a set of spacers. I run 38's and have never had an issue with bumper clearance either on the stock or aftermarket bumper. Check your control arm lengths against the specs in the back of the instructions. Once you get it dialed in, you will be extremely happy with the Teraflex goods.
