Teraflex 3" and factory isolators
So I am going to install the Teraflex 3" tomorrow, and the instructions say to leave off the rear coil spring isolators unless you have a heavy rear. It says to use the fronts though. Here is my question... I have hardtop and plan to get a rear bumper with a swing away and full size spare in the future, but right now only run the factory bumper and no spare. You guys that are running the 3"... Did you use the rear isolators? It only makes like 1/2" diff right? I have a Pure Jeep stubby hanging on the front. I do not want it to rake. Need Help!
Teraflex are you here??? Anyone??!??
I used the stock rear isolators in that I plan to install a heavier bumper and tire carrier in the rear. With the stock bumper and 35 inch tire on the back right not, there is not noticable rake. It would be a pain to put it on later.
yes I just went through this, you also need to make sure that you received the teraflex spring isolators for the rear that are "sometimes" included along with the rear spring retainer bolt set up. there are pics in my gallery, I have the shrockworks rear set up. but you will be dissapointed if you don't have them. and have fun putting in the front springs, and I hope that you got the frnt lower adjustable control arms. I just finished installing them 30 minutes ago and it drives SOOOOOOO much better than it did before. if you need anything pm me and my phone will get the email. im on the mobil site now. and no I do not plan to change the driveshaft, there was two people hanging from the front axle fighting to get the front springs in and I do not see it hitting anything and that was with the shocks disconnected. hope this helps
Thanks everyone for the help. I will put them on. I Dont really want to take it back apart later just to add an isolator, like you guys stated.
Thanks man! I love some jeep people! I went with the 3" kit with front lower flex arms, and rear upper arms. I also added some front and rear adj. track arms (that won't be here until monday), and got the front links as Discos since I don't have a rubicon. It said in the instructions that coil spring compressor may or may not be needed so I got one. In my experience if it says maybe... it means definitely! lol. How much lift did you get from the kit? How much caster did you use? Did you replace the rear control arms too? Sorry for all the questions but you know how it is. There are like 300 different jeeps in your gallery, can you post yours? I think it is the nice white unlimited?
I just threw on a 1/2 thicker spring guide spacer today on my TF 3". And I do run the stock isolator on these as well.
I have a rear bumper w/ tire carrier and I think it was pretty level. But I decided when I load it up for a trip its going to come down a little. So I went from these that came w/ the kit
To these.
To these.
Thanks everybody!!! I can't wait to get this thing on tomorrow! I have read that the lift gives just over 3" in the front and just over 4" in the back. I hope this is the case. I think my 35s will look perfect at that height!
Don't forget to take . I usually get busy doing something and forget to take pics along the way.
