Teraflex 2.5 w/ rear sway bar extensions
The problem in not so much with the rear as it is with the front. The Rubicons with the electronic sway bar disconnect need a longer sway bar link. I guess, they figured if they need to include one, they would go ahead and give you a longer one for the rear which would allow you to use the original rear to extend the front. That way your whole set is longer.
New Teraflex Bump-stop "redesigned"!
I also got all the new goodies with my Teraflex 2.5 budget boost. One of the other things I noticed is that the bump-stops are different from the ones on the Project JK write up.
Notice in the picture the that they seem longer and have a slant on one end.
I just got my Teraflex 2.5 budget boost w/ shock extenders today and to my excitement it also came with a pair of longer sway bar links for the rear. Is this something new they are adding to the budget boost? Do i swap the stock rear links to the front? Nothing is in the instructions or on the web site for this. Anyone got the same set up? I did'nt see this in Wayoflife's write up.
