TeraFlex 2.5" Spring Lift - TESTED
#31
Anybody know how high i will need to jack up my jeep to put this on? Im in my garage here and just need to know how high to get this thing in order to fit the new coils in
#32
Well done on the write-up. I didn't add the extra spacer and my Caster angle is 2.5 and axle shifted 1/2". I feel the combination give me a flighty steering feeling quite often and is more than likely for the occassional ESP. I will be able to prove this once I switch out the lift for a 3.5" lift. These are two components I'm requiring in my next lift anyways.
This one get's the job done (low investment)
I only got the spacer 2.5" with extensions.
#33
I believe I got more than 2.5" out of the Teraflex coils, AZ-JKs front fender measured 24" and mine measure 25.5" in the same spot. Maybe because its a 2 door? Anyone know?
#34
#35
If purchasing this lift without shocks, what size shocks would I need to get? would I need shocks for a 2.5" lift or a 3" lift since the front springs seem to raise it 3"?
#36
Total newbie here, but I'm absolutely convinced that unless caster angle - and I'm talking about when it has "drifted" several degrees off stock settings - is addressed (i.e., with control arms) folks are going to experience flightly steering, or worse (Wobble of Death).
I have the 2.5bb with adapters also and some people on the forum and others off said that I should also get a front track bar bracket. So I did and every time I hit a bump or whatever on the road it felt flighty. then someone else posted up that with the 2.5bb not to use a tb bracket so I took it off. Now it drives perfect like new. from what others have said now and IMO you don't need a tb bracket unless you go over 3" of lift.
Calling JOE at Tereaflex?????? Any thoughts??????
#37
Change one length, angle, roll, pitch, etc and it really changes other components as well. A lift no matter how you do it, changes a LOT; the angle/length of your track bar, which pushes your axle over, binds the control arms and sway bar links, the roll of the axle, its impact on the control arms, angle of the springs and shocks...
#39
No, no word. I just PM'ed Joe and put in a link to this thread so hopefully he can respond. I havent gone back to re-measure, but I know mine has settled more. I'm pretty worried about squeezing 35's under it now. Here is a pic that is not full stuff in the rear, but is up pretty good and off camber... Not much room in the rear there...
They DO use the same shocks you are right. But, if you are going aftermarket, you might be able to fine tune things. I switched out the shock extensions that I bought with my kit and added TeraFlex's longer shocks. They are about 2" longer than the stock Rubi Shock+Extension setup. This is WAY better in my opinion. I get 2" more droop all around, and that helps to keep that tire on the ground and getting traction and moving me forward. I cant give you exact measurements, but I would say it is worth looking into and fine-tuning exactly how big of a shock you put on.
This is a pic of why I need at LEAST 35" tires... Also a great example of why front and rear bumpers can really disable you of they inhibit your approach angle. I think this would need 37's to get over, but you never know when you get lucky and also have the perfect line. I saw lots of WELL built rigs NOT make this fall...
