Teraflex 2.5" Spring Lift Questions
I have the 2.5" Teraflex spring lift coming this week, and was reading through the instal directions and had a couple questions these don't seem to adress very well.
Question 1 is in the rear they mention to remove the clip holding the speed sensor wires to the upper control arm mount. Will this allow enough dropp in the axle to replace the springs. Also once the instal is done will I want to reattach these, or leave them so there is enough room durring articulation.
Question 2 is the tranny skid plate. I know to remove it for while I am doing the install, but with the shock enxtensions will I get enough droop to where I will want to remove it permanently, or trim it, or will my travel be limited enough to where there won't be contact?
I also didnt take the skid off at all... and so far I havent had any issues... then again I am over due for a full check out of everything to make sure she is holding up well... but I think you should be fine with the 2.5'' without moding the skids...
