Teraflex 2.5 question
I have the 2.5" coil lift with shock extensions on a Unlimited Rubicon with soft top. I did not install any coil spacers, only springs and I have no aftermarket bumpers or winch (yet).
I got about +2.6" up front and +2.4" in the rear. These measurements are taken from my rock rail to the ground at both ends of it. Also my jeep is now sitting with a 3/4" rake also measured on the rail front and rear, but it looks about level to my eye.
I don't know how heavy a hard top is vs a soft top, so there is the only variable I can think of. I doubt it would make more than a 1/4" difference, if any, though.
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
I think you asked me this already, I'm not sure to be honest. I didn't measure the exact height of the spacers, but I'm pretty sure the front spacers were taller than the rears. Here's a pic I took, it's hard to tell, but I should have measured them. The front spacer is sitting under the rear one in the picture.
![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
Just has me curious, I guess.
Originally Posted by nthinuf
TF can correct this if it's wrong, but I'm pretty sure that their BB is 2.5" front spacers and 2" rear spacers. If your coils sag a bit, you can end up with less than 2.5", but unless their quality control failed for a day, not sure how you get more than 2.5" on a 2.5" spacer. A coil, yes. But a spacer?
Sponsoring Manufacturer
The spacers are 2.5" front and 2" rear but then if you have the factory coil isolators installed, those can get you 1/4"-1/2" more. I have yet to hear of any of the JK BB spacers coming out taller or smaller than spec.
TF can correct this if it's wrong, but I'm pretty sure that their BB is 2.5" front spacers and 2" rear spacers. If your coils sag a bit, you can end up with less than 2.5", but unless their quality control failed for a day, not sure how you get more than 2.5" on a 2.5" spacer. A coil, yes. But a spacer? ![Don't Know](https://www.jk-forum.com/forums/images/smilies/z0tdntknw.gif)
![Yup](https://www.jk-forum.com/forums/images/smilies/yup.gif)
