TeraFlex 2.5" Problem
#21
So I went on the TeraFlex site vs. Quadratec to look at what the model numbers I ordered were. According to Qtec, the model number for the rear shocks is 1554200 and that is for the range of 2.5-4". The TeraFlex website however has 1554200 as the 3-4" rear shock. The front from Qtec is 1553200 for the same 2.5-4" range. The Teraflex site has 1553200 as the 3-4" front shocks. Kind of confusing since TeraFlex has separate shocks for all of the ranges in height where as Qtec uses 2.5-4" as one shock.
#22
The TF rep is in Moab, as is Most ppl! It defiantly sounds like u got the wrong shocks. Please post pics when u can so we can see.. And I'm sure as soon as joe from TF sees this he will respond.
#23
Sounds like you may have shocks that expect the whole suspension to be a lot taller than it sits with just the spacers in place. I wouldn't draw any conclusions until the TF springs are installed. I think you are sitting at what will be close to the maximum compression of your new springs.
#24
Well I have messed with them so I no longer have the TF bumpstop installed. Only the OEM.
#26
Well, that is also another strange thing. I have had them for less than a year. At first they were installed with the 2.5" Budget Boost Spring pucks which was last summer, then I put the springs on and took out the pucks in order to not have to buy extended brake lines, lower control arms, and drive shaft and thats when it really started happening.
