teraflex 2.5" lift questions
I'm looking at the teraflex 2.5 coil kit without shocks and then adding the bilstein 5100 shocks for a 2-3.5 lift.
my question is how much lift will i actually get? I have a 2dr x model with all factory bumpers still........
if the lift goes beyond 3" am I headed for trouble with my drive shafts?
looking for people with experience with this kit and lifting a 2dr in the 2.5-3.5" range......what problems could i expect and how to fix them
TF coils run tall. You can expect
3+" for a loaded 4door
4" for a stock 2door
The Faq's are a good place to start...
Q: What are all the components that I will need with a 3" lift?
Q: What are all the components that I will need with a 4" lift?
Q: What is Caster? How much do I need?
etc...
A quick search would also be a good use of your time. TF is very popular here, and there are just about a ton of threads to look through. You could also read through an install write-up in the write-ups area.
etc...
