Teraflex 2.5 inch spring & Shock lift installed but JK is not level
This is my first post. I searched this subject and did not see anyone had posted anything similar to the problem I am having.
I just installed the teraflex 2.5 spring and shock lift. I did not have any problems with instalation and followed the instructions perfectly. The JK is running fine, no sqeeks, rattles or weird noises.
I do have a big concern though as my JK still has the forward tilt that it had with the stock suspension. I was under the impression that this lift kit would correct the forward tilt. However my back end is still 1/2 higher in the back then in the front.
The only thing I could think of is I installed the factory spring isolater under the new isolater per the instructions provided. It mentioned if you did not do so the lift would be off 1/2 inch in back.
Should I remove the factory spring isolater to get the front and back level or is there perhaps something else that is wrong? If anyone else has held similar problem or knows whats wrong would appreciated suggestions.
I assume that the 1 inch coil isolator came with this kit? I got the kit without the shocks and upgraded later with the isolator and new shocks. if so you will have an extra 1/2 in on the back. if you plan on adding larger tires the 1/2 more in the back will be benificial to counter the extra weight.
congrats on the lift and hope you find your answer
I know the are other on this forum that have installed the same kit and they adsvised it leveled the truck out. Thats why I am concerned that something is missing or installed wrong.
Re: Teraflex 2.5 inch spring & Shock lift installed but JK is not level
My rear coils are actually starting to sag. I'm going to contact Joe tomorrow. Don't forget your coils will settle so I would hold off on removing the rear isolators.
Any luck with the settling? I just got a 3.25 Rough Country lift installed today and the front is actually higher than the back. Isn't that the opposite of the factory rake? I'm hoping it had something to do with the original parts being in the trunk weighing the back down, not measuring on a level surface or the need for it to settle over time.
