teraflex 2.5 coil and noises?
Just installed a teraflex 2.5 coil, I do have some noises coming from the rear end. When I go over a bump or turn I hear a click/clunk noise from rear end. I do have the rear track bar bracket, I did torque it down, re check it. re- Torqued control arms bolts. I did notice the bolt and nut on the track bar mount seem to come very close springs, is this normal? Would a adj. track bar help, i could get rid of the rear bracket all together, or is it just a loose nut somewhere? Any advice would help.
The post above is a good place to look first, if that doesn't solve it:
Do you still have the stock rear sway bar links? If so, check them. I had a block to drop the swaybar with my old lift and that was causing the stock links to interfere when I put on the 2.5 lift. I removed the block and bought longer links.
