Teraflex 2.5 Coil Lift w/OME LT Shocks
Yes...Teraflex will suggest you add the coil spacer/retainer. I worked with Joe directly on this same issue a few months ago. I think you'll be placing a lot of stress on the Currie retainer for the amount of travel those shocks are giving you.
David
That is less expensive than buying spacers and retainers and I like how it keeps the spring attached constantly.
lmao.. I know. I didn't read that they were the currie ones. Once I reread I remembered they attached top and bottom. So I had deleted the post. I thought I canned it fast enough. guess not...
From Another thread ...
Just be careful...even Currie has stated these retainers were designed as a "safety" in the event of shock failure. I'm not sure how they will hold with the regular stress of keeping stretched coils in place as you flex your JK since your 28" shocks will be out-stretching your coils
Yes David you did answer all of my question. I appreciate all of the time you spent helping out. I purchased my lift kit from you based on all of the positive things everyone on this forum has said about you. I am also very satisfied with the level of service you have provided and would recommend you to anyone looking for a lift for their JK. I just wanted to find out what others might have done to rectify this problem when running this setup.
Thanks Again!
Thanks Again!
