Teraflex 2.5" Coil Lift Questions
As Rexlba said, you should be just fine with just the lift. I've got the 2.5" coil lift with shock adapters but I didn't need anything else. The track bar and LCAs are nice but not necessary. You can always wait and add those on later.
I found the best prices by PMing the vendors on this forum. David with Northridge (Northridge4x4) and Bryan with 4WD (Bustabizz) are always great in responding. Both are very competitive and have the best prices I have found. Not familiar with the other sponsors here but I'm sure can also give you a good deal.
I'm running just the TF coil lift with 35's and to be honest mine drives straight as an arrow without any additional parts. Start with the lift and assess after it's done before ordering anything more.
I agree with this. If you're not satisfied with the way the tires track, then a pair of adjustable trackbars will let you dial that in perfectly. If the steering is a bit too loosey-goosey for you, then front LCAs will let you dial in some more caster. Meanwhile, if you don't have sway bar quick discos and if you off-road, I'd recommend a set. The alternative is to use hand tools to remove the nuts and bolts--a minor pain in the rear, but quite doable. Unitil your sway bar is disconnected, you won't really be able to enjoy all of your added articulation.
I added nothing to the kit and I am very happy with the ride and performance. Save your money for stuff that is more fun...
Oh yeah, got a great deal from Dan @ ORW 1-800-341-7757
