Is the TeraFlex 2.5" coil lift OK for RHD's
Old 02-05-2011 | 12:47 AM
Markdsv's Avatar
Default Is the TeraFlex 2.5" coil lift OK for RHD's
Hi, I am about the order the TeraFlex 2.5" coil lift, swaybar (fr/rr). As my 2010 JK is a RHD, any issues installing the lift?
Old 02-05-2011 | 07:08 AM
wayoflife's Avatar
JK-Forum Founder
don't see any reason why it would be a problem on an RHD. the only thing that would have been a problem is if there was some kind of steering correction provided with the kit but there isn't. also, i'm quite sure that the rear track bar is in the same location but, if it's not, the relocation bracket will not work.
Old 02-05-2011 | 03:14 PM
Markdsv's Avatar
Thank you !
Old 02-06-2011 | 02:16 AM
Blue Fin's Avatar
We've got RHD & run that kit.
You will be good to go
Old 02-25-2011 | 03:05 PM
Markdsv's Avatar
Thanks !! did you change any control arms?
Old 02-26-2011 | 01:45 AM
Blue Fin's Avatar
I ran the TF kit alone for over 6 months, then restored caster with adjustable front LCAs.
It was managable, but things are much better now
