Teraflex 2.5" Coil lift
Hello,
I am considering going with the Teraflex 2.5" lift without the "Teraflex" shocks.
Has anyone tried an alternative, shock which works well for this lift? I read something about the skyjacker shocks being close to stock ride.
I don't care for shock adapters, definitely want a replacement shock. I just don't know if it's worth the $250 extra to get the Teraflex coil kit with shocks.
(sorry if this has been asked before).
Any suggestion from personal experience would be great.
Thanks.
Thanks.
A good thread on the subject
https://www.jk-forum.com/forums/show...l+lift+options
Good luck with your selection process, most of these decisions depend heavily on what you plan to do once you have the Jeep lifted. The coil spring route is a great way to start out but if you are mostly concerned with the look and clearance for oversized tires then the BB might be the better way to go. There are a lot of people I've wheeled with who have done some pretty heavy wheeling on the BB. If you plan to wheel a lot then the coil springs are the way to go JMHO
Thanks for the replies.
JMHO
