Tera flex high angle rzeppa joint
Just installed my newTera Flex high angle rzeppa joint on my new front drive shaft. My old stock shaft finally failed after about 18,000 miles with both on and offroad use. Instal was pretty straight forward with help from the Tera Flex video. The new joint allows for a lot more flex and is way cheaper than buying a new shaft. My Jeep is a 2014 JKUR with the AEV 4.5 lift on 37" Nittos. Before and after pics below: Attachment 636619
Attachment 636622
Attachment 636622
Question for you troyoffroad....
Before you did the swap to the high angle rzeppa joint did you have bad vibs from the stock DS? What is you front pinion angle set at?
And if you did have bad vibs (which I would think you would have if still set at the stock pinion angle) did the change to this high angle rzeppa joint solve the vib problem?
So what i'm wondering is it the stock rzeppa joint or the axle end joint causing vibrations on a stock front DS with the front pinion angle set to stock specs.
OK cool. I've seen that in pics, not in person. I replaced my front with an Adams, I'll replace the rear joint with the Teraflex when it craps out.
Question for you troyoffroad.... Before you did the swap to the high angle rzeppa joint did you have bad vibs from the stock DS? What is you front pinion angle set at? And if you did have bad vibs (which I would think you would have if still set at the stock pinion angle) did the change to this high angle rzeppa joint solve the vib problem? So what i'm wondering is it the stock rzeppa joint or the axle end joint causing vibrations on a stock front DS with the front pinion angle set to stock specs.
