Tera Flex 2.5" suspension lift and rear adjustable track bar...
Originally Posted by aldaman
If you feel flightiness, front lower control arms will help with that. The LCAs will help you adjust your castor to eliminate that flighty feeling. Adjustable track bars are used to center the axles...
i am sorry to say but i would totally disagree with your assesment. you can totally drive straight and just fine with your axles being off center and people do it all the time. due to its very nature, if you were to load up your jeep with heavy bumpers and a ton of gear, your jeep could lose as much as 1/2"-3/4" at the front or rear or both and, that would cause your axles to see a measureable shift. and, in spite of it, you wouldn't have any new flightiness. there are several things that will help address flightiness but the one that will do the most is more positive caster and, you can only add more with adjustable control arms. while caster is normally set with upper control arms, on a small lift like this, adjustable lower control arms will allow you to do the same thing and with less effort.
