tera 2.5 BB install..any pointers??
Old 01-24-2007 | 09:45 PM
Default tera 2.5 BB install..any pointers??
i got the kit in today
the parts look self explanatory, but in typical Teraflex fashion, the instructions totally suck
if anyone has installed one, are there any tips or tricks before i dive into it this saturday???
Old 01-25-2007 | 05:29 AM
Jake_Blues's Avatar
I would go and borrow spring compressors from your local auto-parts establishment, just in case.
-E
Old 01-25-2007 | 07:09 AM
07RubiJK's Avatar
Where did you get the lift and how long did it take? I have one back ordered through Quadratec and was told it could be weeks. I might call and see if any are coming in. I already put my spacers on and have the tires ready, just need the lift!
Old 01-25-2007 | 07:25 AM
wayoflife's Avatar
JK-Forum Founder
This is a write-up I did for the Full Traction 3" Econo Lift and it should be able to help you out as much of it is the same thing
3" Lift Installation Write-Up
Old 01-25-2007 | 07:56 AM
TexasChopper's Avatar
07Rubi sent you a PM
Old 01-25-2007 | 10:19 AM
i got the kit from 4wd, i believe they said that it was the last one they had in stock..not sure though..it got here 5 days after i ordered it
Old 01-25-2007 | 11:47 AM
YjtoJk's Avatar
Default Teraflex BB
UPS has been trying to deliver mine for the last 2 days! Apparently they need an adult signature (over 21yo) to release, but for those of us that work for a living it's hard to be home for delivery. No other options were given on the note for an alternate delivery location.
I'll be wrenching come Saturday morning........will post pics after.
Old 01-25-2007 | 01:01 PM
ThinkMud's Avatar
yeah man if you need help during the install let me know, we did mine no problems, just make sure you do not put the front bumpstop extensions on until AFTER you put the spacer on!! it took us an hour to get the bumpstop back out b/c we put it on first, and the spacer will not fit over it. and make sure you have a jack under the axles to keep them from dropping down all the way, b/c with out the shocks on, they will fall far enough to break your brake lines and stuff. I"ll pm you my number incase you need to call during the install....
Old 01-25-2007 | 05:26 PM
lnufnu's Avatar
Hey make sure you let us know how your install goes, I recieved mine yesterday as well and will be installing Saturday morning. So any lessons you learn would be greatly appreciated... unless I finish first
LnuFnu
Houston, TX
Old 01-25-2007 | 07:36 PM
YjtoJk's Avatar
Default Kit shipped incomplete
Well, I received my Teraflex 2.5" kit today, but it's missing one of the brake line extension brackets.
Hopefully Quatratec will be able to fix this quickly by sending me another part. I sent them an email this evening explaining my problem. Unfortunately these kits are drop shipped from the vendor.
Soooo, check your kit contents before tearing your Jeep apart......frustrating.
