Taking her in tomorrow
Old 08-05-2009, 09:05 AM
Ryanc's Avatar
Default Taking her in tomorrow
Allright guys, I put my lift on myself, and tomorrow I am going to take it in to have someone (who actually knows what they are doing) do the alignment, and rebalance the tires because I am getting a slight vibe at 55mph. I think I did a pretty good job initially, but want to put it up on the rack and see where I am at. My drive is close to stock, but I have some "flightiness to it". Based on my best guess, my castor is at ~6-7 degrees. What castor angle should I have them target, toe in degree?
Old 08-05-2009, 09:10 AM
RedneckJeep's Avatar
I think you're guess is high on the caster. As you lift the Jeep, caster decreases. The 6-7 degree figure you mention would be a good area to be. A lot of Jeeps drive good with less.
Old 08-05-2009, 09:19 AM
Sponsoring Manufacturer
TeraFlex's Avatar
I have about 3 degrees on my caster with my 4", 4-5 would be better for yours.
Old 08-05-2009, 09:56 AM
Ryanc's Avatar
I think you are right Redneckjeep, I am still a little flighty on the steering. I heard that with the increase in castor to around 7-8 it feels pretty "hard", and I do not feel anything like that.
Old 08-05-2009, 09:57 AM
Ryanc's Avatar
I will let them know that tomorrow. Thanks Joe.
Old 08-05-2009, 10:10 AM
nthinuf's Avatar
Have you got an angle finder?
I'd be curious to know the before and after numbers on the finder vs the before and after on the machine.
http://project-jk.com/jeep-jk-write-...-end-alignment
Old 08-05-2009, 10:40 AM
Ryanc's Avatar
I do and will post once the aligment is completed.
Old 08-05-2009, 11:43 AM
mewaschuk's Avatar
I just had my OME HD kit alligned 2 weeks ago. Enged up with 5.3° L/5.7° R and 0.125" total toe. Dives nices and no vibes. I statred with the LCAs at ~24" and that resulted in about 1.5° castor and it drove terrible. Much beter now
Old 08-05-2009, 11:56 AM
Ryanc's Avatar
Wow, 1.5. Do you just have the LCA, on the front. I currently have my front LCA at 23.25. It does not drive terrible, I could probably live with it, just want to have it checked out.
Old 08-05-2009, 12:13 PM
MoridinTX's Avatar
Originally Posted by redx08
I have seen it before, but why is there different castor on each side? I am curious.
wouldn't the difference in caster between wheels contribute to a pulling effect to one side
Quick Reply: Taking her in tomorrow
