Takeoff Mystery
Old 05-21-2014 | 03:07 PM
Stoneaxe's Avatar
Question Takeoff Mystery
I have a short mystery that I could use some sage advice on... So my JK has had a 'stutter' at takeoff. More like a 'skip' that seems to be in the driveline somewhere. Only in forward gears (4 hi, 4 lo, and 2 wheel), does not do it in reverse. When pressing accelerator slightly, there is a type of hiccup or pause. If you quickly press the accelerator it will pass through this 'pause' and proceed normally.
Now it started doing this thing a few weeks ago. A couple things happened. First it was doing this thing so I updated the software on my Superchips and then updated the Jeep. Changed the programming from 93 performance to 87 performance. Made things worse if anything.
I noticed a small transmission fluid leak. That turned out to be a severely corroded transmission oil pan cover. Got a new cover, new filter and new fluid. Still doing the 'pause' thing.
Then I had an engine light stating a misfire. Turns out that was a bad plug wire. Got new plugs/wires and no engine lite and no actual engine stutter when it's cold/wet out. Still doing the 'pause' thing.
I believe these events to be unrelated to the original 'pause' issue. Sort of a series of isolated unfortunate events weirdly coinciding.
The pause thing in the driveline is still going on. Driving me bonkers cause I can't seem to figure it out. Perhaps a stickly valve in the auto tranny somewhere?
Any insight from you folks here would be helpful.
Peace.
Old 05-21-2014 | 05:47 PM
jeepin_tiger's Avatar
I might be a little off, but my first thought was a sticking valve in the tranny. I forget the name, but had the problem in higher gears on a f150 I owned
I could recreate it by easing on the brake while still maintaining speed with the accelerator. Granted, this was higher gears where as yours seems to be with 1st.
Old 05-21-2014 | 08:21 PM
Mr.T's Avatar
If you haven't tried going back to stock with the tuner, I'd try that first and if there's any change.
Old 05-25-2014 | 06:42 AM
Stoneaxe's Avatar
I should have tried that first. I updated the software on the programmer, returned the Jeep to stock, and then reprogrammed with tire size/gearing only. The stutter went away. Then added the "87 Octane" tune and all seems well.
Old 05-25-2014 | 11:53 AM
Mr.T's Avatar
Great!
Old 05-25-2014 | 01:14 PM
JLsJK's Avatar
Quick Reply: Takeoff Mystery
