Tailgate Strap Problem
The way the thing is designed, it doesn't serve as a travel limit, so I don't see how the heavier tire would be a factor.
When I was installing mine, it pulled out of the fixture without breaking anything. It was tricky getting it back in.
At what point on the rod did yours break? (I have assumed it was the hidden end. Maybe yours broke at the tail gate end?)
(There is a thing that looks like it could be a strap, but it's only the cover for the wire harness.)
I thought the other posters had a strap (they seemed happy about). Maybe they're making the same assumption I was.
Either way, the check rod has a different purpose than a simple strap would.
The way the tailgate stops is by the hinge.
After replacing mine with a teraflex hinge you get a good view of how it works. Basically they have a bend in the hinge housing that connects to the body of the tub, and as the hinge opens it gets closer to this bend, and once it reaches it it stops the tailgate from going further.
The strap does not do anything other than cover the wiring. And the metal 'stop' found in 2011+ models is only there for keeping the tailgate open on an incline.
The stop is built into the hinges.
edit: Here's an image I found that shows what I'm talking about
Between the bolts on the portion mounted to the body, and the actual hinge that moves you see that the metal is grooved slightly up, when you open the tailgate the back of the hinge (the part past the pivot point) swings towards this and eventually catches on this groove preventing it from going further.
Has anyone figured out how to put the rod back into the housing? I went to the dealer and they told me Chrysler isnt covering this anymore. My dealership made the claim that 99% of these issues occur because of user error in opening the tailgate. What a load of crap. Trying another dealership now. Not hopeful though.
Dealer Stories?
I just took my 2012 JKUR into a dealer today after scheduling an appointment by phone and explaining all the little gripes in detail. The service tech told me they wouldn't cover the hinge issue. Jeep should be embarrassed by this design issue, especially considering it's happening to stock or very close to stock vehicles (I'm assuming everyone with super size wheel sets has a high quality aftermarket carrier that eliminates the weight on the swing gate). It seems like owners are all going to the aftermarket to find a fix for a weak design that fails far from the limits of the vehicle's rugged performance in other measures. Really disappointed in this. Has anyone had any luck in getting a dealer to cover the fix?
