Tailgate rattle
Old 01-11-2014 | 07:26 AM
Jk-Jared's Avatar
Default Tailgate rattle
Recently moved up to a 33 inch tall tire and mounted it on the tailgate and every time i hit a bump in the road it rattles is there a cheap fix I don't have enough for a tire carrier at the moment...need help
Old 01-11-2014 | 07:35 AM
MASJKF84's Avatar
Is it snug up to the bumps on the tailgate? If not get a set of these and it might help. Should be able to get them on amazon.
http://www.daystarweb.com/productdet...?productID=381
Old 01-11-2014 | 07:36 AM
karls's Avatar
Don't carry your tire, carry air and a patch kit until you can afford a carrier.
Old 01-11-2014 | 08:56 AM
Jk-Jared's Avatar
Originally Posted by MASJKF84
Is it snug up to the bumps on the tailgate? If not get a set of these and it might help. Should be able to get them on amazon. http://www.daystarweb.com/productdet...?productID=381
Idk if those will work i look in my mirror to see what it's doing and i can see the tire just wiggle I'm pretty sure it's the mount and or the tailgate hinges
Old 01-11-2014 | 08:58 AM
Ncb's Avatar
Ncb
You're saying you can see the wheel/tire wiggle when hitting bumps? Are the lug nuts tight? Check to see if the mount is cracked.
Old 01-11-2014 | 09:07 AM
BlackRockBurner's Avatar
Take the wheel off the back and tie it down in the cargo area. I'd rather have a spare than a patch- kit.
Old 01-11-2014 | 09:22 AM
Jk-Jared's Avatar
need the cargo space it's my daily
Old 01-11-2014 | 09:44 AM
ToolManTimTaylor's Avatar
This. Not only do they crack but the spot welds on the tailgate fail easily
Old 01-11-2014 | 11:37 AM
sea bass's Avatar
If it is your hinges, you can replace them with stronger, greaseable units. Be sure to check what everyone else is saying. Make sure your tire is tight against the rubber stops.
http://www.oesales.com/JK%20GREASE-A...GATE%20PIN.htm
Old 01-11-2014 | 11:42 AM
karls's Avatar
That's interesting......I wonder if they provide any benefits. I've replaced a couple sets of hinges due to a lack of grease but it took a long time for the corrosion to build up to the point where they needed to be replaced.
What does suck about that is they won't be easy to grease without a 90* elbow on your grease gun and a narrow nipple.
Quick Reply: Tailgate rattle
