t case blew up
t case blew up
sooo im driving down the interstate and i start to hear a noise but ive got my doors off and everthing so when i heard it it was too late and all of a sudden i hear a horrible noise and i pull over and look and the bottom of my trasfercase is gon and my front drive shaft is sitting on my t case skid and you could seee straight up in to the t case.. its sitting at my cousins lot and im going to pick it up with my car trailer tomorrow.. but what do i do? where do i k\take it? is my ring and pinion on the front going to be shredded? and i want to know abt the atlas t case.. thanks.
First, lets see if we can determine what caused it.
How many of these things apply to your Jeep?
Lifted
Aftermarket front drive shaft with a double cardan at the t-case
Adapter at the front of the t-case that places the double cardan farther away from the t-case
Angle of front pinion and the drive shaft greater than a few degrees
Re-geared
Traveling at or above highway speed
Lifted
Re-geared
Lifted
Re-geared
Lifted
Re-geared
How was your front pinion aligned with the drive shaft?
A double cardan at the t-case requires the single at the front to have no more than a very few degrees of misalignment between drive shaft and pinion.
Another factor is maintenance. How often have the u-joints been greased.
That could just be someone saying "Yeah, that'll be fine". And, some people get away with it. It's all the things that add up that can cause the drive shaft to vibrate to a critical point.
