Synthetic Gear Lube?
Old 01-28-2010, 05:50 PM
Hiball's Avatar
Default Synthetic Gear Lube?
What's a good synthetic lube to put in the diffs? I'm thinking about changing the gear lube from conventional and going to synthetic. I want to reduce thermal breakdown and increase lubrication.
Old 01-28-2010, 05:52 PM
Weeds's Avatar
Thumbs up
Royal Purple
Old 01-28-2010, 05:53 PM
CLOTAGAMES's Avatar
Looks like quite a few use royal purple, seen quite a few other posts using Mobil1.
Old 01-28-2010, 06:00 PM
Hiball's Avatar
Is there a specific weight or is it just diff fluid?
Old 01-28-2010, 06:08 PM
Biggy's Avatar
Im running Amsoil
Old 01-28-2010, 06:11 PM
thom1879's Avatar
75w-90 royal purple, a little pricey, but if you stay out of the deep water you can feel easy about going longer between changes
Old 01-28-2010, 06:18 PM
jeepn7658's Avatar
I have royal purple in one and mobile1 in the other (they didnt have enough of either at the store for both axles).
Old 01-28-2010, 06:20 PM
Hiball's Avatar
Looks like Royal Purple wins, thanks guys.
captjay's Avatar
Royal Purple Max Gear Synthetic Gear Oil | 85W140
with ARB lockers
Old 01-29-2010, 03:03 AM
Mark Doiron's Avatar
Originally Posted by SNOWOLF
What's a good synthetic lube to put in the diffs? ...
I've used Mobil 1 and Valvoline. The reason I've switched is because sometimes it can be difficult to find the brand/quantity you need. Generally, I prefer Mobil 1 (been using Mobil 1 synthetic lubes in all of my vehicles for nearly four decades).
From the '07 owner's manual:
Axle Differential (Front): Mopar Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent.
Axle Differential (Rear) 198 RBI (Model 35) and 226 RBI (Model 44): Mopar Gear & Axle Lubricant (SAE 80W-90) (API GL-5) or equivalent. For trailer towing, use Mopar Synthetic Gear & Axle Lubricant (SAE 75W-140) or equivalent. Models equipped with Trac-Lok require an additive.
Note (from me, Mark) about the Trac-Lok (Limited Slip Differential) additive: Both Mobil 1 and Valvoline have the correct friction modifiers and DO NOT require the additive. Adding the additive when it's not required (or using too much or not using any when it is required) will cause differential problems. Know your gear lube if you have LSD!
BTW: Can't personally confirm this, but some people with what seem to be good credentials have writen on this forum that the JK is delivered from the factory with all synthetic lubes.
Quick Reply: Synthetic Gear Lube?
