Synergy tie rod on aev lift?
Over the weekend I found a large log (after setting out to only conquer rocks) that got perfectly between my steering stabalizer and my tie rod.
My poor stabalizer is garbage lol. I took it off.
My tie rod is slightly bent. The jeep still dives perfectly fine but I can see the bend so I don't trust it one bit.
Done some research and I want to get the synergy tie rod but I am unsure if it will work/fit with my current set up.
I am running a 3.5" aev lift with the high steer kit
Also I have no idea on the back spacing I am running. I know to fit the tie rod you need 4-3/4 back spacing.
I'm running pro comp 7105 and I believe they are 4.5 wheel spacing but I was hoping someone could chime in and help me out here.
Also, going to need to replace my stabalizer as well. I was thinking of just buying another OME as that what I had on the jeep before. Wondering if it is even worth the money to buy the synergy one that is rebuildable (and if it will fit with my aev set up)
The internet claims a 4.5bs for 17X8 and 4.750bs for 17X9 so you should be good to go. The Synergy tie rod will work fine with your setup. I'm running a JKS ss so can't speak for other, but given the tie rod is the same diameter as stock, I don't see why any ss wouldn't work as it would on a stock setup.
I should also add that I recently had an issue with a Synergy product (not the tie rod) and they were outstanding in making it right and getting me a good part. Great communication and customer service.
Also hoping you're in stock in Canada as that's where I am...
For the first time I noticed that your price is 370 while other websites are 325. Im assuming the 325 is american dollars so i would have to pay duty but i eould still be paying 13% taxes on the 370. i think it would work out to be a good $40-50 more expensive. Anything we can do about that?
