Synergy Tie rod & 15's
#23
I figured as long as the castle nut lines up with the hole it should be OK ?
Looks odd because it tapers in on the bottom. I took the boot off and measured the distance and there is about 1/8 between stock and this one.
I did not install the tie rod. Wanted some feedback first.
Thank you .
Thank you .
#25
Stupid thing didn't post all i said... Lol. Anyways was saying I'm getting my tie rod this weekend hopefully. And that i want to get some 15s with my taxes. Just dont want to make the purchase if they might not fit.
#28
The Poly Drag link end will require you to ream out the stock knuckle to fit the end. The Poly tie rod does not require any reaming of the knuckle.
