Synergy springs sagging!! Please help
thats a lot of money. Lol. New links and shocks. It looks like spacers are the way to go. Just blows to be ripping apart for the fourth time in 4 months @ 75$ every time for an alignment. Blah.
Former Vendor
Guys, do you have adjustable sway bar links? You can always have the passenger side links a little longer than the driver side, (especially in the rear) and it will help level the vehicle!
That will compensate well for the gas tank skids and things that add weight strictly to one side of the rig.
In general as long as everything is square it should be relatively square...
Good luck fellas
RK
Good luck fellas
RK
Guys, do you have adjustable sway bar links? You can always have the passenger side links a little longer than the driver side, (especially in the rear) and it will help level the vehicle! That will compensate well for the gas tank skids and things that add weight strictly to one side of the rig. In general as long as everything is square it should be relatively square... Good luck fellas RK
