Synergy Springs
#22
Your setup looks great. If I added a 1" spacer in the front I would be way past level. Did you add the spacer at the beginning or did the springs settle and required the spacer later?
We are heading up to hit some snowy trails today so I will take a few pictures of how mine sits. I measured mine against the stock height measurement off the axle and I gained 3 1/4 over stock.
Sent from my iPad using Tapatalk
#23
Your setup looks great. If I added a 1" spacer in the front I would be way past level. Did you add the spacer at the beginning or did the springs settle and required the spacer later? We are heading up to hit some snowy trails today so I will take a few pictures of how mine sits. I measured mine against the stock height measurement off the axle and I gained 3 1/4 over stock. Sent from my iPad using Tapatalk
